Highlighted
Note 9 Power Cycling
JUMP TO SOLUTION
Hi.
My Note 9 goes through spells of power cycling. It started on Saturday. I booted it in safe mode and didn't have issues for about 24 hours, then it started again, so I did a factory reset, and am still having issues.
Any ideas @SamsungQue
1 SOLUTION
Highlighted
Re: Note 9 Power Cycling
JUMP TO SOLUTION
Found a solution : Disabling the finger print sensor. It has something to do with it putting out so many bad readings that it crashes the phone. A reset will NOT help. Disabling the finger print sensor did the trick.
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Followup, still having issue. No SD card. No water damage. No overheating.
Not sure what's causing this. Smiley Sad
Highlighted
JUMP TO SOLUTION
Honestly, I would recommend having the phone evaluated by a certified technician. You can do so by visiting a local uBreakiFix location or you always have the option of sending it into the Samsung service center.
Highlighted
JUMP TO SOLUTION
