userb0ujVGjXai
Re: Note 9 car bluetooth pairing issue
Please to me where to find messaging pair on my Note 9.My bluetooth keeps disconnecting..
Thank you for your help!
userb0ujVGjXai
userOkBkvAdGR0
I'm having the same issue with my note 9 and my 2012 Rx450h. It will connect for phone calls but within seconds the media pairing goes away.
Sean28
I had the same issue with the note 9 and Bluetooth in my escalade  I went ahead and cleared the storage caches as someone had indicated earlier but what really worked for me was to go into Bluetooth from the settings communications menu and then click on the three dots in the upper right corner  From there I selected advanced and then turned on the dual audio.  At that point I was prompted to disable the media volume sync which I did by selecting ok and then the Bluetooth worked fine . I still kept the contact access .
Hey guys, can you all provide the following information:
Model code of Phone: (This can be found under About Device in the settings)
Baseband Version:
Carrier:
Model of Radio:
Make/Model of Car:
We are currently looking into this and will report back once we have more information. Thanks!
J C
Cosmic Ray
Note 9
2014 Chevy equinox
Baseband  N960USQS1ARH6
J C who is your cell phone carrier? For example, do you use Verizon or AT&T etc?
J C
Cosmic Ray
Sprint
SomeTechGuy
Cosmic Ray
2016 Honda accord sport(non android auto) wont connect. Had a note 8 and had no issues. Have the unlocked note 9.
Doesnt even see the phone when I try to pair with bluetooth.
Disregard, I see where you have posted in another thread as well. Smiley Happy Thanks!
