usertyj88romrq
Re: Note 9 car bluetooth pairing issue
SM-N9660U
VERIZON
2011 LEXUS GS350
user3Y8C4OnftB
Model code of Phone: SM-N960U
Hardware version: Rev 1.1
Carrier: Verizon
Model of Radio: Stock
Make/Model of Car: Fiat 500
Won't allow media audio... only contacts and phone.  Immediately shuts off when go to toggle it. Had a iPhone that never had problems and I just got the note 9 and it worked fine for 5 days or so and now it will not work
usertDHRYmiMJZ
Model: SM-N960F
Serial: <Hidden>
Baseband version: N960FXXU2CRLT
Carrier: PrimeTel (Cyprus)
Car: Range Rover Evoque 2018
Radio: original Range Rover Radio without CD
Same issues as everyone with my note 9 One UI.
Thanks
usereSuarIBnbT
 2012 Lexus RX350, Verizon is provider. Will only Bluetooth contacts, not media.
userMGZbjnOGtR
Had the same issue and this solved it for me.
Delete from your car, unpair from your phone, as above turn on dual audio in (connections, Bluetooth, three dots, advanced, dual audio to on) and then reconnect Note 9 to your car.
userFUEmuYnT3b
This 100% fixed mine.  Got the new note 9 -  My phone had paired once and worked great - next day I could dial but nobody could hear me and I couldn't hear them. ...used the fix below and instant and so far (several weeks later) permanent resolution.
Rocky194568568
Note 9 deose pair with my uconnect but when playing music it starts to crackle but stays paired I tried everything if the note 10 deos that am done with Samsung
userb0ujVGjXai
Where to go to find messaging pair on my Note 9..My bluetooth keeps disconnecting.
Thank you for your help!
usergRYeoXJ1Y3
Mine as well, only mine doesn't automatically pair now, deletes my paired devices, and will not pair with the headphones that I got with the purchase now. It was fine 2 days ago. All of a sudden it is now not pairing and won't pair when I try to pair them.
user4Qj7vLPRM2
Mine is doing the exact same thing with my 2018 Ford Escape, Samsung watch, everything bluetooth. It is pissing me off. Please fix error soon. It can not be that difficult to fix.
