userD2tgIIJ1Xn
Re: Note 9 speaker problem
JUMP TO SOLUTION
Actually i just tried it again and it does the same thing in safe mode
JUMP TO SOLUTION
It seems a factory reset may be in order. Please be sure to back up all of your data prior to doing so.
userD2tgIIJ1Xn
JUMP TO SOLUTION
Ive done a factory reset twice already
JUMP TO SOLUTION
This may require service repair if the previous trobuleshooting has not been successful. Before offering a ship-in repair, I'd recommend taking it to a UbreakIfix or visiting https://www.samsung.com/us/support/ubreakifix
user7wwF3T0HQG
JUMP TO SOLUTION
Did that its still doing that with the speaker
userYSe7eBGidX
JUMP TO SOLUTION
My phone does the same thing.  It's quite a few people that are experiencing the same problem.  What's happening is that your speakers are switching to "in-call volume." It happens on every single app that uses your speakers.  Nothing that these people have suggested will help.  I'm looking for a permanent solution myself. We may have to wait for a software update.
userPkncgL2fYu
JUMP TO SOLUTION
Having the same problems with mine... Samsung needs to step up the build and qc for these $1000 phones.
FYLegend21
Cosmic Ray
JUMP TO SOLUTION
I've seen some of the changelogs for One UI/Pie beta which has things like "audio breaking and playback speed fixed". This specific issue has not been listed but a bunch of similar ones seem to be addressed. It seems like if I don't change it to max media volume it is fine but once I do it starts happening. I don't recall it happens with PowerAmp (which uses Direct Volume Control independent of the default Android audio thread).
userbGqb9KxrcX
JUMP TO SOLUTION
My phone does this as well and I have been waiting on a patch, but nothing. If a lot of people are having this issue, then it's a software issue for sure. Plain and simple. Hate when technicians say your phone is faulty when its widespread. $1000+ for a phone and I keep getting the run around.
userVEaQV63Hha
JUMP TO SOLUTION
Too many problems with Note9 speakers. Low notification volume, that this. And for monhts now. Nobody replied. Nobody fixed. Next time buy non-Samsung phone, their support is the worst at this moment.
$1000 for what? For issues? No thanks.
