Highlighted
Note9 will not connect to car Bluetooth
My Note 9 doesn't connect to my car Bluetooth anymore why?
4 REPLIES 4
Highlighted
Re: Bluetooth problems
Neither does mine. Thought it was me.
Highlighted
This is likely due to the head unit not supporting Android 10. Please check with the head unit manufacturer for any available updates.
You can also try forgetting the pairing on both devices and then re-adding/re-pairing them.
Highlighted
Cosmic Ray
I guess you got the answer from Samsung Moderator.
Anyway, if not then follow the instruction from the below article,
https://www.technobezz.com/how-to-fix-galaxy-note-9-bluetooth-issues/
Highlighted
Cosmic Ray
Here is another website that can help.
https://www.bestusefultips.com/fix-bluetooth-connection-problem-on-galaxy-note-9/
Hope it solves your issue.
