Supernova
Re: S-pen remote won't connect
JUMP TO SOLUTION
@userIecxvwm7fV: What type of case are you using on the device?
userG19G3AUKKA
JUMP TO SOLUTION
I'm sorry. I'm confused. How is this the solution?
I need a real answer
Supernova
JUMP TO SOLUTION
@userG19G3AUKKA: I apologize for the confusion, we did have a community member state their case was causing an interference with the S-pen.
userG19G3AUKKA
JUMP TO SOLUTION
Understandable. However, I dont have a new case. Is there another possible explanation as to why my s-pen wont reconnect to my phone?
Supernova
JUMP TO SOLUTION
@userG19G3AUKKA: Can I get the following information.
Model Number
Baseband Version
Carrier
userG19G3AUKKA
JUMP TO SOLUTION
Model number: SM-N960U
Baseband version: N960USQS1ARH6
Carrier: Verizon
Supernova
JUMP TO SOLUTION
Have you tried clearing the cache of the Bluetooth?
userG19G3AUKKA
JUMP TO SOLUTION
No. How does one do that?
Supernova
JUMP TO SOLUTION
You can clear the Bluetooth cache by completing the following.
  1. Settings
  2. Apps
  3. 3 Vertical Dots
  4. Show System Apps
  5. Bluetooth
  6. Storage
  7. Clear Cache
  8. Clear Data
  9. Restart Device
userG19G3AUKKA
JUMP TO SOLUTION
That did not work unfortunately
