krystlyn
Samsung Note 9 camera buzzing sound + unable to focus
JUMP TO SOLUTION
Hi i am currently using a samsung note 9 and it has been less than a year since i got it but recently i realised everytime i use my camera in the live focus mode it gives out a buzzing sound and keeps vibrating. The picture is also blurry as it cannot focus. I've seen many others complaining about this  problem too. May i know if there is a solution to this (ie will it help if i send it to the samsung repair centre?) I am actually very disappointed with the new software update as we waited so long for it to be released and yet there are still so many problems.
1 SOLUTION
Honored Contributor
Re: Samsung Note 9 camera buzzing sound + unable to focus
JUMP TO SOLUTION
Can I have your full model code and IMEI number via private message?
17 REPLIES 17
userwuokzYHeUW
JUMP TO SOLUTION
I called Samsung initially and they referred me to Ubreakifix... they couldn't fix it. Tech told me the camera might need replaced and advised to call Samsung back. I'm calling them later and will post back with the result.
userZWqho1PmKN
JUMP TO SOLUTION
camera hardware failure. a widespread issue. sell your device after its fixed or exchange to s10, the problem will just comeback after the replacement.
userjc84MGDtXq
JUMP TO SOLUTION
Did not go via Samsung, did go with my provider and they're sending me the second replacement phone because of this issue. I am a longtime Samsung customer, but this will be my last phone from them!
Honored Contributor
JUMP TO SOLUTION
@krystlyn
Give this a shot.
Go to Settings > Apps > Show system Apps (click on the 3 vertical dots upper right of screen) >
 Camera > Storage > Clear Data and Clear Cache.
 Restart Phone
user7PQ3w3525d
JUMP TO SOLUTION
I tried that and it didn't fix it. Mine does the same thing in every mode for the camera.
useri5kN526zcq
JUMP TO SOLUTION
That worked. It fixed my problem
Honored Contributor
JUMP TO SOLUTION
userenEL0WRD62
JUMP TO SOLUTION
mine as well pls help
JUMP TO SOLUTION
Hey there @userenEL0WRD62,
Can you send a private message here with your model and IMEI number?
