userDmDKpLSB2B
USB connection issues
JUMP TO SOLUTION
Main issue is that my Note 9 does not read thumb drive. After looking at USB settings, the USB controlled by setting is stuck on Device. I can't change it to Phone. Any advice would be appreciated.
1 SOLUTION
userDmDKpLSB2B
Re: What is the thumb drive formatted as?
JUMP TO SOLUTION
Got around it by downloading CFX file explorer. The app picked up the thumbdrive right away.
5 REPLIES 5
Samsung Care Ambassador
JUMP TO SOLUTION
userDmDKpLSB2B
JUMP TO SOLUTION
userk8IQYIDTo9
JUMP TO SOLUTION
MAC IOS 10.5
userk8IQYIDTo9
JUMP TO SOLUTION
MAC OS Extended Journaled
Android devices can't usually read NTFS-formatted drives...
JUMP TO SOLUTION
Android devices can't usually read NTFS-formatted drives without a special app as NTFS is uniquely Windows.
