Highlighted
Wireless charger duo flashing red lights after being plugged in
JUMP TO SOLUTION
I have been using the wireless charger duo for a while now and today I was going to go on a vacation and I didnt want to take the entire wireless charger with me so I unplugged it and only took the cable and put it in my bag. I ended up not going on the trip and took the cable out of my bag and plugged the charger back in and after plugging it back it in, both indicators started blinking red without me even putting my phone on it. It won't let me charge my phone. How do I fix this. I have already tried a different outlet.
1 SOLUTION
Highlighted
Re: Wireless charger duo flashing red lights after being plugged in
JUMP TO SOLUTION
Are you using the original charger that came with the device?
3 REPLIES 3
Highlighted
JUMP TO SOLUTION
Highlighted
JUMP TO SOLUTION
I have same problem. Using same original charger. When plugged back in flashes green then keeps flashing red.
Highlighted
I don't want
JUMP TO SOLUTION
I don't want
