Highlighted
using S7 Charger with the note 9 for the first use
JUMP TO SOLUTION
Hey everyone..
so my problem is that i got my new Note 9 but without charger (yet)...
i didn't even boot it up ... my question is ... if it's normal to use my old S7 edge Charger
to charge it for the first time (6-8 hours charge) ... i read their voltages and currents ..
they seem to have similar ones ... is there something that prevents me to charge it this way ?
i have the USB_C cable so i can charge but will it harm the batteries ?
1 SOLUTION
Highlighted
Samsung Care Ambassador
It should be fine.
JUMP TO SOLUTION
It should be fine.
3 REPLIES 3
Highlighted
Re: using S7 Charger with the note 9 for the first use
JUMP TO SOLUTION
We would recommend using a charger that comes with the device or a Samsung original charger.
Highlighted
JUMP TO SOLUTION
it is a Samsung original charger ..
but an old one (for S7 edge) ..
that's why i'm hesitated
Highlighted
It should be fine.
JUMP TO SOLUTION
It should be fine.
