userKbK8EoWFdK
Re: wireless charger duo blinking red and not charging
Hi all,
my duo charger charges the my phone perfectly, any orientation and on either pad, however, when I put my Gear S3 on the pad it doesn't seem to reccognise it?
I tried moving it around various ways and sometimes it would try to charge and then drop out.
The design of the horizontal pad has a recess which I assume is to allow for the shape of the watch, the parts of the watch where the strap connects are lower than the back of the watch, I tried pressing the watch with very light force onto this recessed pad and it worked, charged the watch, but it is very delecate, if you move the watch it stops charging, it is as if the charging field is very weak although it will charge the phone with no issues?
Any ideas? There are no protective covers on either device or charger and all plastic has been removed.
Cheers,
Richie.
userKbK8EoWFdK
Hi there,
I don't know the law where you are, but, in Europe your contract is with the shop or wherever you made the purchase, they are obliged to replace or refund you.
The shop has the contract with Samsung so they need to take up the issue of the defective product with Samsung directly - nothing to do with the customer.
Richie.
usersqAJdlF5bf
I have the same issue.
@userK8ikKDAlEp wrote:
I have my wireless charger duo which comes with my note 9 as my buying package.
it is ok when I first used it, it charged and the led working fine, but it began to not charging properly and only blinking with red led in both indicators.
where did I go wrong?
as now I can only charge my device conventionally by cable, my disappointment is inevitable
userwAXWCEv2Ck
Make sure you use the charging cube that came with the duo Charger. I accidently switched the duo cube with a regular Samsung cube and it caused that same issue with the blinking red lights.
user7MnvgNkWGg
Make sure you are using the wall charger that came with the Dual pad charger. It is slightly larger than the standard wall charger.
user8t6UY1ZtHp
I'm having the same issue
useraC5XBabFTM
same issue here and i just got it today
Spoiler
@useraC5XBabFTM; Just to clarify, the charger was not working when you received it?
userBFn2cEKmCv
I have the same issue, and yes.
userBFn2cEKmCv
Turns out I was using my Note 9's charger. I used the wireless charger's power brick and cable and it worked perfectly. Hope this helps!
