Owen-M
Halo
Android System Battery Drain on Note 10+
JUMP TO SOLUTION
Android system draining 30% of my battery. I reset my phone and nothing helped. I started completely new after the reset except for contacts, phone calls and texts. This seems very unusual and this didn't happen on my S10+. Is there any fix???
1 SOLUTION
Michael_01
Galaxy
Re: Android System Battery Drain on Note 10+
JUMP TO SOLUTION
Ohhh ok so you have and at&t, they are known to load them with bloatware, just delete everything and disable everything from them. I also have one from tmobile but its disabled by default
40 REPLIES 40
Michael_01
Galaxy
JUMP TO SOLUTION
I have been having this issue on my s10 plus also but it's not a huge impact like yours mine is around 13-10%
Honored Contributor
JUMP TO SOLUTION
There are times where google app could be doing this and/or Play Store app.  The play store app gets updates periodically too.  Something is not letting your phone idle properly.
Owen-M
Halo
JUMP TO SOLUTION
Its so weird, I'm still trying to find a fix. Just got this phone on Saturday (9/28/19) from Best Buy. I think I might have found a culprit. I went to apps and I found that bixby voice wake-up was using 48% over the label 'Android System'. Maybe this is it but even so thats an 18% difference from the 30% shown in device maintence. But even so 30% is still odd.
Honored Contributor
JUMP TO SOLUTION
Disable voice in bixby settings if you can.  I don't really use bixby, so I didn't setup voice function.  Also I have seen mobile data to stay active even though it was not needed anymore.  Did you update all apps in Play Store and Galaxy Store?
Owen-M
Halo
JUMP TO SOLUTION
I disable voice wake up and I always turn mobile data off when I'm on wifi. All my apps are updated on both stores I'm just not sure what's causing the idle drain
Honored Contributor
JUMP TO SOLUTION
Which carrier are you using?
Owen-M
Halo
JUMP TO SOLUTION
I use AT&T
JUMP TO SOLUTION
Can you please provide me with a screenshot of the battery consumption for today and for the week? Also, give this link a try: http://www.samsung.com/us/support/troubleshooting/TSG01001451/
Owen-M
Halo
JUMP TO SOLUTION
Here is my battery usage from today
