Re: Android System Battery Drain on Note 10+
JUMP TO SOLUTION
It definitely looks like Youtube Vanced is using a lot of battery. On my personal Note 10+ I don't have any crazy battery drainage with normal Youtube.
Michael_01
Galaxy
JUMP TO SOLUTION
I agree with @SamsungJace its definitely YouTube Vanced the app taking most of your battery try to uninstall it for a day or 2 and check back in
Michael_01
Galaxy
JUMP TO SOLUTION
As you can see this is my usage from today in the s10+ with 5 hours of on screen and I still have 35%
userX8mXShLZ4Z
JUMP TO SOLUTION
Mine does the same with my note 8 any solution to fixing it
Samsung_vw7M3kF
JUMP TO SOLUTION
Nerf all your un needed apps and run in a more effective mode ir just use a charger when playing.
Michael_01
Galaxy
JUMP TO SOLUTION
@userX8mXShLZ4Z for you download the app in the play store called phone info and check your battery cycle as the note 8 is a lil bit older
Owen-M
Halo
JUMP TO SOLUTION
Update : My battery life was pretty much the same with normal youtube but I switched my phone to 1080p and the battery life is extremely good now. Still disappointing I can't get normal battery life on 1440p like on my s10+
Michael_01
Galaxy
JUMP TO SOLUTION
Strange you should go to a Samsung store and get that check out and maybe get a replacement because I use 1080p on daily basis but if you still cant get advantage of the big battery, I would go to your local samsung store.
Owen-M
Halo
JUMP TO SOLUTION
I think I'm just gonna stick with this battery as I don't want to ruin the water resistance of my phone and the only Samsung repair shop in my entire city is a UBREAKIFIX.
Michael_01
Galaxy
JUMP TO SOLUTION
Got it I mean you might as well talk to an operator from the samsung members app- live chat and ask for an estimate if you need to pay or is it going to be a free replacement
