10-10-2019 10:40 AM
@Michael_01 The battery would be covered under warranty unless there is physical or liquid damage to your device.
10-10-2019 10:42 AM - edited 10-10-2019 10:42 AM
Also try to clean cache partition data as in my galaxy s8 would get hot by doing nothing and when I did that it fixed it
10-10-2019 03:22 PM
I reset my cache partition a couple days ago and it didn't help. There was no new update. I've read things that it gets better after a week or so I just have to wait it out and see, I have been getting slowly better battery life so I just want to see where it goes
10-10-2019 03:56 PM - edited 10-10-2019 03:56 PM
Turn on everything and make sure to have every app in sleep mode. What is the % of the android system
10-10-2019 05:20 PM
I've already done that but I think I found the issue. Apparently a lot of threads say that battery drain is a big issue with Att Note 10 phones. They all say to turn off AT&T Network Diagnostics. To do this, Settings>Connections>Mobile Networks> AT&T Network Diagnostics
10-10-2019 05:31 PM
Ohhh ok so you have and at&t, they are known to load them with bloatware, just delete everything and disable everything from them. I also have one from tmobile but its disabled by default
10-10-2019 05:36 PM
Let me know if you anymore problems
10-10-2019 05:36 PM
Will do, thank you!
10-11-2019 02:23 PM - edited 10-11-2019 02:23 PM
Update: after turning off the diagnostic data setting I am now getting phenomenal battery life. For anyone on att, turn this setting off
10-11-2019 04:51 PM
Nice!!! I am happy you resolved the issue at&t is known to load Androids with Loats of bloatware, just the galaxy fold if I am not wrong has about 10 apps from at&t
