Highlighted
Battery Note 10+
As of this past couple weeks, I've noticed that my Note 10+ battery is draining slightly faster than usual. I have made sure to put all the apps I use to Sleep when not using them. Typical apps I mainly use are Samsung Internet browser, Google Play Books, YouTube, and Instgram. I've cleared the Cache and I always optimize the phone when possible via the Device Care widget. I thought the One UI 2.1 update would fix but its remained the same. I do use the 45W Super Fast Charger, can that damage the battery? I only charge it when my phone notifies me that I'm on 15%...it hasn't even been a year, the battery shouldn't be starting to show signs of going out already...
1 REPLY 1
Highlighted
Re: Battery Note 10+
Search Samsung service place ask Replace battery.
Remember do not leave your phone all night with your charger plug in.
Maintain percentage 40% to 80% if you could or unplug as soon as reach 100% or little less.
