Battery and heating issues
A couples days ago i got a security patch update and after that my phone started to slightly heating up and drain my battery after 35 minutes of using it I turn off my phone load it up and did a clean partition and didn't help or calm it down witch its funny cuz when I bought the phone it didn't used heat or drain as quick as like right now and I hardly download any apps and I only use my phone for a while then get off when I'm bored its just so annoying and of course feeling my device warm is normal but it didn't used to pass little warm heat
1 REPLY 1
Re: Battery and heating issues
