Highlighted
Battery drain and software issues
Samsung needs to fix battery drain and over heating issues ok android 11 also when I'm recording and I switch between zoom options it freezes when I play the video like please fix all this issues it's not like s20 series is that important you guys have the note 10 that just release and also needs some work its not all perfect or good yet when I use my camera to record and I press play some how the camera itself crashes and fails to record whatever I'm recording please push and update to fix all this problem when I bought the phone it didn't used to heat up as bad as now or drain as well after the first few updates when I got the phone it really screw it all up smh
1 REPLY 1
Highlighted
Re: Battery drain and software issues
I've Got the10+. NO Issues!!! might want to call Samsung.
