Bobbydrakes
Cosmic Ray
Blue light Filter problem.... and fix it.. (note10+)
problem starts after installing the update last november 14, 2019..
tried turning on my blue light filter  nothing happens even its already max out..
 i tried installing third party app from google play store.. try installing  Blue light Filter - from Leap  Fitness group.. after using for minutes .. turn it off. then try using the buildin bluelight filter on ur note10+ ... its fixed..
hope it will fix urs...
Samsung please fix the bug...
