userJvIMv5tD5T
Bluetooth Audio Quality
Occasionally when using Bluetooth headphones, sound will become distorted as if compressed. It is particularly prominent during music. I've tried three headsets, and they all present the same problem. Toggling Bluetooth off and on temporarily fixes the issue, but it is still extremely annoying.
Troubleshooting so far performed:
Turning off Battery optimization for Bluetooth, Spotify, Play Music, etc.
Observed if the issue occurs with wired sets (no issue)
Re-pairing headsets
Resetting phone and headsets
Has anyone else experienced this issue?
4 REPLIES 4
Neutron Star
Re: Bluetooth Audio Quality
Re-pairing headsets
Do you have WiFi on?
Is this 2.4Ghz or 5Ghz wifi?
userJvIMv5tD5T
Yes. 5GHz. It's campus WiFi, so my phone switches between routers as I walk around campus. Could that be causing the issue?
Re-pairing headsets
Neutron Star
Re-pairing headsets
I have seen issues where 2.4Ghz would cause some interference, but 5Ghz shouldn't.  Just for testing purposes, try disconnecting wifi for 30 or so min and see if it comes back. To me, your issues sounds like Bluetooth not having enough bandwidth...does this issue happen when you are at home too?
userJvIMv5tD5T
I did not notice the issue until I was on campus. It would make sense then if it was related to wi-fi. However, the issue is subtle enough that I may have simply not noticed it until now. The wi-fi on campus may also have 2.4GHz, and the issue seems to crop up most frequently as I walk around, so it seems the wifi has a high probability of causing the issue, specifically shifting between networks. I'll see if turning off wifi while walking around solves the issue.
Re-pairing headsets
