Highlighted
Charging issues Note10 plus
7 REPLIES 7
Highlighted
Re: Charging issues Note10 plus
Thank you for reaching out! Will you please elaborate more on the symptoms you are experiencing with charging your phone?
Highlighted
Its only occurs when I plug in to charge my phone and it turns into that screen. Also, will instantly become normal once unplug from charging
Highlighted
Can you please provide me with a picture of your normal screen so I can see the difference?
Highlighted
Highlighted
Does this still happen when your phone is in safe mode?
Highlighted
Nothing change ...still remain the same
Highlighted
Thank you for confirming. I recommend that the phone be evaluated by a certified technician. I will be happy to see what options are available. Please send a private message with the full model code and the IMEI number of the phone. http://bit.ly/2XERsky
