Highlighted
Does wired dex have better resolution than wireless dex?
I'm just wondering if wired dex has better resolution. I feel like since wired dex has more stable connection and zero delay, the quality would be better. Are both wired and wireless dex the same resolution?
2 REPLIES 2
Highlighted
Cosmic Ray
Re: Does wired dex have better resolution than wireless dex?
I believe wired DEX only supports 1080p. I haven't been able to get 4k wired to work on multiple Samsung devices.
Highlighted
Re: Re: Does wired dex have better resolution than wireless dex?
Really? When I go wireless dex, it's fixed on 1440p.
