Face-Down Wireless Charging?
(Topic created: 08-24-2019 08:15 PM)
melka_ashur
Galaxy Note Phones
Just confirming, there is no way to charge a Note10+ wirelessly face-down correct? Only to charge other items from the phones screen (Power Share), right? I ask because I use a thick leather case, where the back of the phone is not exposed but the screen of course is. Thanks!
NBI
Nebula
Galaxy Note Phones
Yeah Wireless Charging won't work with face down, it needs to be charged by the back of the phone touching the wireless charging pad. Yeah so you'll need a case of certain thickness so that wireless charging will work.
NBI
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
NBI
Nebula
Galaxy Note Phones
NBI
M3dicat3dV3t
Galaxy Note Phones
Power share has to be done from the back of the phone, not the screen.
melka_ashur
Galaxy Note Phones
Actually "wireless powershare" is done FROM the phone TO other devices and IS DONE from the SCREEN. For example placing the earbuds on the screen when wireless powershare is turned on. But wireless CHARGING where the phone itself is being charged apparently is only done from the back of the phone.
