Highlighted
Galaxy note 10+ low Battery temp
Need help fixing.Cant charge phone. Error message battery temperature to low. Seemed to come on after an update.
Anyone else having issue.
119 REPLIES 119
Highlighted
Re: Galaxy note 10+ low Battery temp
Same issue! No fix yet. called t mobile and Samsung, neither provided a solution.  If I have it connected to a power source, the charge level remains steady, won't charge but won't lose power. This started last night for me, randomly. Two hours after it began, I had it plugged in and it randomly charged from 5% to 65% in 10 min. Then after a while the charge dropped 40% out of nowhere.  Robot Sad
Highlighted
Yep mine just started doing it as well.  I have a battery monitoring app and it says the battery temp is -4 degrees.
Highlighted
Thank you for reaching out. I would be happy to assist you further. Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
Highlighted
Why would anyone take this to a private measage? We all know what your trash policy is. Leave your customers without a phone for an extended period because your $1000 dollar flag ship phone has a lnown issue you recuse to address. No SamsungTool,  we would not like to hear about your solution, unless you have changed your policy and are providing actual service to your customers rather than placing them in a vulnerable state that for most people would hinder or possibly terminate their employment.
Highlighted
Yes I am having the same problem.  shows battery at -4 when it wont work.
Highlighted
I am having the exact same problem.  I have took it to UBreakIFix and they said it is the motherboard and has to be repaired by Samsung.  I have called twice and cant get any response!  After dealing with the old Samsung 7 battery issue and now with this I have a very sour taste in my mouth regarding Samsung  All I want is for them to fix this phone....
Highlighted
@user61X4A32JKj I will be happy to assist you with this. Can you send a private message providing the full model code and IMEI of the device? http://bit.ly/2GGYul4
Highlighted
Look jojo you cant do anything, samsung wont actually help its customers. You can help by getting me the number to the nearest apple store maybe.
Highlighted
I have the same issue with my note 10+. My first phone I had to exchange after 3 days for the same issue and now again with my new one. It could be a sensor that reads the battery temp and isn't working properly. Samsung needs to fix this asap.
