Galaxy note 10+ low Battery temp
(Topic created on: 11/11/19 3:33 PM)
Samsung_LLXgNvO
Note10
Need help fixing.Cant charge phone. Error message battery temperature to low. Seemed to come on after an update.
Anyone else having issue.
JUMP TO SOLUTION
Samsung_nuILV1h
Note10
This is a charging port issue. Try charging the phone wirelessly. If it charges normal then its 80% a problem with a port. I have fixed this issue many times on various samsung devices. It's very rarely a logic board issue.
dlewis1000
Note10
Please read my replies. This issue is a known manufacturer defect as told to me by the certified Samsung repair facility(ubreakifix). They are not publishing any information on the topic as I'm sure it would cost a ton of money like the note 7 did.
useruvYWTCEeSg
Note10
This is definitely not a charging port issue. I'm about to get my third phone due to this problem. Wireless and wired charging both won't work. Low temp warning for any type of charging.
user1Judy6CQO0
Note10
From my experience as a repair technician I'd say it is the wireless charging pad causing this error. The pad also has a temperature sensor in it so if it has a tear or is not getting the right connection it will cause that error.
userx7hNN4CG55
Note10
Had the phone about a month, just started doing this a few days ago.  Depending on the orientation of the phone, the battery temp registers as -4f and the phone won't charge.  If I tilt the phone different ways or set it upside down, it will start to charge.
The phone was not dropped, nor gotten wet, although with the IP68 rating which I count on in the summer for beach/boating season it shouldn't matter.
Support was not helpful, I was told to blow into the USB port for 1 minute then shake the phone for a minute.  Ultimately it was suggested I mail the phone in (and be phoneless for weeks I'm assuming) while it gets repaired.
I am not interested in a repaired phone that's barely a month old.  I will not trust this repaired device that has been sliced open and rebuilt to have the IP68 rating which I count on.  I'm not going to have the phone damanged by a splash of water 1 day after my warranty ends because the phone had a manufacturers defect within the first month.
What is going on with Samsung quality lately? I've been a customer since the first Galaxy S Fascinate came out years ago, but my last few Samsung products have all had issues.  Brand new Q7F TV developed a horiztonal line of damaged pixels within 3 months.  Q8F replacement had a similar issue.  And my Q9F has been rebooting, recieved 2 repairs to try to fix the issue, then found out it was finally fixed via a firmware update.  So my TV was ripped apart for nothing but a software bug.  Ridiculous.
I'm very disappointed with both Samsung's quality, and customer service.  If this cannot be made right I think it will be time for me to abandon this brand for good.
user0f4SfB0YaM
Note10
This happened to me this morning. I totally panicked and got my old phone out. I took out the sd card and the AT&T chip/card, and put them in my old phone. I turned off the phone that would not charge. About 20 minutes later I turned the phone back on without the SD & at&t cards. I plugged in the charger cable, and Bam!! Charge's again. I don't know if this is a temporary fix, but it works for now.
Col_BatGuano
Note10
This afternoon my Note 10 stopped charging then started saying the battery temp was too low to charge. The phone was warm to the touch definitely not cold by any means. Now the phone is completely dead with zero charge. Attempted to restarted the phone at least a dozen times and it continued to show battery temp to low to charge.
SamsungQue
Note10
@Col_BatGuano Does this issue still appear when your phone is in safe mode?
Col_BatGuano
Note10
Yes, it also remains even after restarting it at least a dozen times
SamsungQue
Note10
@Col_BatGuano Have you tried wiping the cache partition on your phone? Here are the steps.
  1. Turn off the device.
  2. Press and hold the Volume Up key and the Bixby / Power key.
  3. When the Android logo displays, release both keys.
  4. An 'Installing system update' message will show for 30 - 60 seconds before the Android system recovery menu options appear.
  5. Press the Volume down key several times to highlight wipe cache partition.
  6. Press Bixby / Power key to select.
  7. Press the Volume down key to highlight yes, them and press the Bixby / Power key to select.
  8. When the wipe cache partition is complete, Reboot system now is highlighted.
  9. Press the Bixby / Power key to restart the device.
