Galaxy note 10+ low Battery temp
(Topic created on: 11/11/19 3:33 PM)
Samsung_LLXgNvO
Note10
Need help fixing.Cant charge phone. Error message battery temperature to low. Seemed to come on after an update.
Anyone else having issue.
JUMP TO SOLUTION
Col_BatGuano
Note10
Not possible, the battery is dead. It's getting mailed in on Monday to be repaired
userLNShwGfz6K
Note10
Tried this and it doesnt help at all
SamsungAdam
Note10
@userLNShwGfz6K Are you using the original charger that came with the device when you experience these symptoms? Have you tried another Samsung charger when you are experiencing these symptoms? Does your charge wirelessly when you are experiencing these symptoms?
Samsung_jA1h7Ef
Note10
I called Samsung support today and they told me that this was not a common issue. Obviously it is an issue for more than just myself. They said my only option was to mail the phone in, and wait a week with no phone. My phone says I have 1% on my battery but I've been on it for an hour and its not dead so...
userXvR2b1eDp3
Note10
Yes. Safe mode doesnt do anything for the issue. Cant reset the phone because it wont charge therefor not helpful. Called att told them of the issue and demanded that i get s10÷ because it is more than likely a hardware issue. Its being sent now
ramori
Note10
This is happening to my new Note10 today (09DEC2019). Cannot charge, message says "Battery too cold to charge". Then in a few minutes I'll get "Battery too hot to charge". The phone is not hot or cold, it is sitting inside my house which is 70F.
So I downloaded a phone sensor app, to monitor battery temp.
I think the defect is in the battery temp sensor.
The app tells me that the battery temp is 30C, and the charging comes on. Then 10 seconds later the app tells me the temp is -20C, and the charging stops.
Samsung, any advice for Note10 owners on this?
@Col_BatGuano
Col_BatGuano
Note10
Mine was reading a constant -30c
SamsungAdam
Note10
@ramori I would recommend service repair. Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
userFH6gXthQNQ
Note10
That happened to my s8. Had to get a replacement charging port. The temp sensor inside was broke
Col_BatGuano
Note10
So a week later it went to Samsung for repairs, I have received it back and it still has the same problem. Not good Samsung, at this point I just want to return the phone and be done with samsung
