Levistras
Gesture for One Handed Navigation doesn't work on Android 10 with 3rd Party Home and No Nav Bar
If you're on Android 10 (using Note 10+ Canadian Model here), and you have a 3rd Party Home Screen and the Nav Bar Disabled (gesture navigation), then the gesture to launch One Handed Operation does not work.
You're supposed to swipe down near where the home button 'would be' to trigger it, but it does nothing.
When I go back to One UI home screen this gesture starts working again.
Back on Android 9 there was no issues with the One Handed Operation gesture and 3rd Party Home apps.
