userzZLCYTc47T
How to hide battery percentage during charging note 10?
During the phone is charging, it shows small white text at the bottom of the black screen like
xx÷ charging
xx min until full
Can Iturn it off?
Thanks.
8 REPLIES 8
Comet
Unfortunately there is no built in option to turn it off...
Unfortunately there is no built in option to turn it off but you can download app made by Samsung from Galaxy Store which is called Good Lock app. In that app you'll see Lock Star, tap on it and turn it On, in there under Style section long press on one of the style you like and tap edit. In there you'll see option called Item Visibility tap on it unselect the Help Text and that should turn off that display. Also From the app Good Lock you can also add some customization and features that are missing in Android Pie.
NBI
If you've found my post to be helpful, please like the post. If my response resolved your issue, please press the "✓ Accept as Solution" button.
Samsung_YQzLMTM
Good Lock does not turn this off on the Note 10+.
user_dave
Is there any way to turn this off then? I can see this ca...
Is there any way to turn this off then? I can see this causing burn in at at some point.
Samsung Care Ambassador
Re: Is there any way to turn this off then? I can see this ca...
@user_dave there isn't a way to turn this off at present. You will be happy to hear that burn in is prevented by moving the pixels periodically ever-so-slightly. 🙂
userlEP3E46cnB
Re: How to hide battery percentage during charging note 10?
still no way to turn off this? i'm afraid will burn the screen
Amber_Free72814
Smart
Smart
Samsung_wU9etbd
Samsung if you're listening please have an option to turn this off i just dont want burn in on my screen overtime.
useryls8WtJp4i
The only way is to charge the phone while its off
