Oddle
LED Cover
I am wondering if there is any way to use the LED Cover as a clock..  I have a wireless charging stand and would like it if the clock function of the coverstayed on throughout the night so I can use the phone+cover as a clock.
Thanks
2 REPLIES 2
Re: LED Cover
I do not believe this is an option due to the battery usage it would cause. Even if on the charger, it would be pulling power. However, if it does exist, I would think it would be in the settings of the LED app.
Samtastic
Cosmic Ray
Re: LED Cover
You could probably affix a clock to the case.
