swbeg
Low call volume on note 10 plus
I have no problem with the volume on my apps, but when I am talking to someone on the phone, the volume is so low, I have to make the other person repeat and ask them to speak louder cause I don't understand half of what they say. Even on the maximum volume, that is a big problem that I did not have on my previous Samsung phone. Will there be a update to rectify this. Or do I have to change my phone?
5 REPLIES 5
Re: Low call volume on note 10 plus
Tap and hold phone app shortcut on your home screen. Then when context menu appears, tap on App info. Then go to storage and clear data.
Which carrier do you have?
Your phone is unlocked or carrier branded?
swbeg
Clearing data does not improve the volume.
My phone is unlocked and I am with Virgin mobile which is one of the best mobile network where I live.
Do you use any bluetooth headsets or you just hold phone to your ear?
swbeg
I hold my phone to my ear or talk on speaker. I do have bluetooth hesdsets but I don't use those to answer calls.
But when you do use BT headset, does it sound proper and doesn't have low call volume?
