userzgbyN1UbAX
MMS over wifi from Note to NOte
Ok so I have an issue. I have AT&T service and cannot send a pic/MMS over wifi to my wife's Note 10 plus. When I attach the pic or mms it shows actual size and takes 5 mins to send. When the send completes after 5mins, it actually compresses the image to finally send. When I use cell service and attach it does not compress at all and sends instantly. Now, when I attach a pic/mms to text any other device (iphone or other android) it attaches and instantly compresses and sends over wifi. I did not have any issues with our previous Galaxy 8s. After spending hours with AT&T they said its a samsung issue and suggested I just send over cell service. Samsung support blames AT&T. This makes no sense to me at all. It does not matter what wifi I connect to it will not send mms from note to note but is fine any other device. Any suggestions or is anyone else having this issue?
21 REPLIES 21
Samsung_8PxdjO7
Re: MMS over wifi from Note to NOte
I am having the same issue 🤦‍♀️🤦‍♀️
userzgbyN1UbAX
We cant be the only 2 lol. Hopefully a fix will be here soon!
Maybe Samsung can chime in as well.
userzgbyN1UbAX
Bumping so maybe a Samsung rep can help here.
users8SXqkzbwb
I had the same problem. Tmobile tech support finally fixed my issue
userzgbyN1UbAX
I spent 2 hours with AT&T with no resolve.
MMS has to send through the service providers servers. As your phone sends and receives text messages, the phone is working correctly. You will need to pursue a resolution through AT&T.
userzgbyN1UbAX
This makes no sense as I can send an MMS to other androids and Iphones via wifi. Just not another Note
It could be in the routing between the two phones. Not every message routes the same. You will need to pursue a resolution through AT&T.
Honored Contributor
@users8SXqkzbwb
What did T-Mobile guy do to fix it?
