Highlighted
Moisture detected need help
My Samsung Note 10 is unable to charge because it shows Moisture detected but I am very sure the port is not wet can someone help?
5 REPLIES 5
Highlighted
Re: Moisture detected need help
mine happens this a lot too, I'm using a hair dryer on both the cell phone connector and the charger.
Highlighted
Cosmic Ray
Try connecting it to a pc via USB, then unmount it and disconnect the USB cable.
Highlighted
have you fixed it?
Highlighted
No, still got it
Highlighted
if you connect the fast charging usb cable to your phone before connecting wall charger this will set off the moister detection notification.
