Highlighted
My phone says its phone temperature is too low and does not want to charge
What do I do I've checked the temperature and still it wont charge
4 REPLIES 4
Highlighted
Re: My phone says its phone temperature is too low and does not want to charge
Highlighted
Moderator: Did you actually read this post? It states LOW TEMPERATURE NOT CHARGING. Your response link has zero relevance.  My note10 started this same issue and I'm stuck with a $1000 phone that won't charge and I can't use. I have no idea what to do.
Highlighted
Product Expert
@Samsung_7r5KfOs
@userffnC2Gk787
              I'm sorry to hear you guys are experiencing low temp on your Note 10. This type of issue requires a hardware repair. Reach out to 1800 SAMSUNG and they will be able to help you with sending in the device for repair.
Highlighted
 I called yesterday, received a ticket number for repair, and took it to a local service center. 24 hours later and the hardware repair is successful. I have my phone back working as it should. Thank you.
@Ydania
