Highlighted
NOTE 10 + Not charging with cable or Usb data port not working
June 2 2020 Samsung Update Broke My Note10 + Its lo longer letting me charge it with wire cable, I have to use the wireless option.
 I try all this thing:
 1.-I try to charged it with the Original cable and brick 45w did not worked
2.-Did the Hardware reset using volume down + power keys did not work
3.-I try connecting the phone to the computer the USB are not working also;
4.Reboot the phone several times same thing still not working
5.-Reboot my phone started it in battery safe mode still not working
  All seems clear to me something was put on the phone by the June 2 2020 update, that blocked the USB & charging port since it’s the same piece of hardware for both functions.
Its anyone else having this problems ??
2 REPLIES 2
Highlighted
Re: NOTE 10 + Not charging with cable or Usb data port not working
Do you receive any error messages when trying to charge with the wall charger?
Highlighted
I am suddenly having issues with my note 10+ charging this morning as well.
The weird thing is it doesnt work with the original charging cable and charging brick that came with the phone. I am currently using a 3rd party cable and brick that doesnt support fast charging. So my phone is charging like a snail now.
However, the original cable and brick that came with my note 10+ is not faulty as I managed to get charge when trying with my old phone, a LG V30+.
