Johnatr
No notification sound while on call. HELP!
No notification sound/vibrate while on call
Not sure what's wrong
Phone > settings > call Alerts and ringtones > notify during calls ON.
HELP?
5 REPLIES 5
Supernova
Re: No notification sound while on call. HELP!
HELP?
Are you using bluetooth headset or just the phone to your ear?
Johnatr
Just phone to ear
Supernova
@Johnatr wrote:
Just phone to ear
Tap and hold phone app shortcut on your home screen. Then when context menu appears, tap on App info. Then go to storage and clear data.
After that when you open phone app, check to see if the toggle for notify during calls is on or needs to be turned on.
sastone75
I did the above mentioned as I have the same issues. It didn't work. Things I've tried so far> reset network settings, reset all app settings, wipe cache partition, phone settings ensuring notification in call is toggled to on position, went to messaging app and ensured notify during calls is on (Verizon Messages+ app), went to settings>apps>messages and ensured all notifications are enabled, software is up to date, apps are up to date, security updates are up to date. I've even master reset the phone and started from scratch, still no notifications during calls. This is happening on all of our Samsung devices Galaxy S10+ (with Pie), Galaxy S9 with Pie, Galaxy S7 (with Oreo). I've ensured all settings are correct on all devices. Bluetooth is not enabled on any of them so that isn't the issue either.
Johnatr
Same
Nothing changed
