uservuyljXdgZt
Note 10+ Phone Vibration Problem
A thousand dollar phone that came with headphones that didn't work (kept on muting the phone as soon as I plugged them in)
and now the vibration motor just died.
This phone is 8 days old. I tried restarting it, Factory resetting it, and nothing worked..
1 REPLY 1
Re: Note 10+ Phone Vibration Problem
Hello there, I'd like to look into this for you but I'll need a bit more information. Did the headphones still mute your phone when it is safe mode? When you say the vibration motor died is it no longer vibrating when receiving a phone call or text message even with the vibration mode turned on? What other troubleshooting steps have you attempted? I don't give you steps you've already tried.
