Iceman89
Note 10 Plus Charger Port
Is the USB type C cable that us into the charge port for your phone loose? Does it stay connected, but just wiggles? Is this normal or should it be snug and firmly stuck in place?
1 REPLY 1
MrRad
Cosmic Ray
Re: Note 10 Plus Charger Port
I have the Note 10 plus and my charge port is kind of loose but the way I corrected it was by buying a new cord. However, they both kept a charge, the newer one just fit more snug. I also found that my phone protector needed to be adjusted so it did not inadvertently make the connection loose.
