Note 10 Plus - Eayphone issue
When I connect different earphones it says "The connecymtes USB device isn't supported".
Is there any solution for the same issue?
Bcz of this i cannot even connect my phone to car's infotainment systems.
1 REPLY 1
Re: Note 10 Plus - Eayphone issue
Are you trying to connect via USB-C or Bluetooth?
