RedCat96
Re: Note 10 Plus Signal Signal Issues
An update....
I'm still having the issue. The phone becomes unusable with anything less than 3 bars of service. However, I've discovered if I turn wifi off when cell service is low, the phone functions as expected.
I've tried to return the device at Verizon for another Note 10+ and they gave me some kind of runaround that "the system won't let us DOA it." BS. From here I'm forced to work with "customer service."
userUDmmIzDSHr
Hp Printer are featured with high-quality techniques and components, but sometimes there are technical problems that can damage Hp Printer performance. If you are stuck in the same situation, or facing any trouble with the Hp Printer, connect with us via our Hp Printer  and avail the best support from skilled technicians and professionals.
Red Giant
Haganjeff
@RedCat96 wrote:
An update....
Hey Redcat, are you still having the reception issue?..I was in 3G today in a good 4G area and I remembered what you said about turning the WiFi off.. I turned it off and rebooted into a 4G signal. I have held that signal all day even going to the lake and low signal areas. Drove back through the area I was in 3G and the phone held strong 4 G, never going above - 106db...I know it's a small sample size, but think there may be something to this.. Curious how yours is doing now?
Red Giant
@RedCat96 I couldn't reply to your post with the image...this website has issues at times.
I do see in the image the signal isn't that good.  If you would have another device there and compare to which band both phones connect, that would be really good.  I am thining that the area might have couple of signals from Verizon towers and Note10 possibly got band 13(700MHz) and tries to hold on to it even though the signal is low.  It is possible that Samsung will have to re-work the threshold of the signal strength algorithm.  Basically the phone should release the cell tower at a certain dB and connect to another one if it exists in the area.  If you turn on airplain mode, wait 10 sec and then turn it off, your phone still connects to Band 13?
1) Does your phone have WiFi calling from Verizon and it works properly?
2) When you mentioned "when having wifi on, you can't make call in the area", check to see if your phone switches to wifi calling, where wifi is bad.   Normally if you just connect your phone to wifi(without any wifi calling), it shouldn't mess around the normal cell tower and prevent user from calling.
user7irjLttNC0
@samsung
ive had the note 4, 5, 6, 7, 8, 9 - and now the 10+ 5g - and its signal is terrbile. Places (like my office where i normally have a great signal) just dont work. miss call - text mesages dont go through. Plan to return mine.
user3Q2GDfYdXF
I have a Samsung J7 and calls that I've had in the past a...
I have a Samsung J7 and calls that I've had in the past are no longer having signal. Why is i/ doing this
user3jEHhUECPr
Re: I have a Samsung J7 and calls that I've had in the past a...
My wife had the S10+ with horrible reception issues; she ended up going through a lot of pain with Samsung and Sprint to finally return her device and obtain an IPhone XS Max.  ALL signal issues went away everywhere she had issues.
I have been a devote Note person owning 2,3,4,5,6,7,8,9; never really had an issue with signal and HOPED the issues that plagued the S10+ were not propogated to Note 10 Plus.  Well yesterday was my 14th day with the device and at the ball field in a very well known area with FULL bars I could not obtain internet.  Numerous reboots and 1 out of 5 times I would get ONLINE/internet but only briefly then it would drop.  My wife sitting next to me with IPhone XS Max (same carrier) had FULL signal and internet the ENTIRE time.  I think Note 10 Plus might be having EXACT same issues that plagued the S10+.  Before yesterday I had some spotty issues with reception but nothing as bad as yesterday.  Of course yesterday was SW update (09/01) update too.  I will give it a few weeks and if it does not improve take it back and EAT the $500 to cancel lease and pick up an IPhone 11 PRO and be done with Samsung all together.
userb5Bhr0LmKQ
Same issue.  Where my old Note 8 worked fine, no reception.  My carrier did all is could remotely, but did not enable the 10+ to keep cponnections.
Red Giant
People that have issue, could you please download LTE Discovery app from Play Store and post screenshot
