Highlighted
Note 10 Plus Strong Vibrations while playing audio over stereo speakers
JUMP TO SOLUTION
Just purchased a note 10 plus yesterday, while watching media with the stereo speakers I can feel strong vibrations on the back of the phone. This happens when the volume reaches 30% and up. I had a note 9 before this and never noticed vibrations, just wanted to know if this is normal.
1 SOLUTION
Highlighted
Supernova
To me this vibration is normal during playback of media c...
JUMP TO SOLUTION
To me this vibration is normal during playback of media content. Phones getting slimmer, thinner, having no bazel pretty much and we want louder and better speakers. I feel that speakers create a vibration on different phones. My S10e did this, Note 10 does. Even iPhone Xs did. Unless you guys really feel the vibration motor, then it would of been a problem
48 REPLIES 48
Highlighted
Re: Note 10 Plus Strong Vibrations while playing audio over stereo speakers
JUMP TO SOLUTION
@userR9eY6KrkSc Have you made sure that your phone is up to date on its software?
Highlighted
JUMP TO SOLUTION
Yes, its running N975U1UEU1ASH4 from security patch august 1, 2019.
Highlighted
JUMP TO SOLUTION
@userR9eY6KrkSc Does still perform in the same way when your phone is in safe mode?
Highlighted
JUMP TO SOLUTION
Just ran the phone in safe mode and played some audio. No change, the phone still has vibrations all over the back glass panel.
Highlighted
JUMP TO SOLUTION
@userR9eY6KrkSc Can you send me a private message using this link here? Provide the following information.
  • Model number
  • IMEI number
Highlighted
JUMP TO SOLUTION
Hey samsungque I'm also having the same issue on my note 10+.. Can you please help me with this ?? Phone is updated to the latest version...
Highlighted
JUMP TO SOLUTION
I'm having the same problem too. Help needed.....
Highlighted
JUMP TO SOLUTION
Hi I am in uk scotland and I am having same issue and I have tried soft reset and safe mode and been into settings and switched of all vibration  buttons it's like there is a hidden speaker  under back cover as vibrates to much and is uncomfortable  in hand . Alistair.
Highlighted
JUMP TO SOLUTION
My phone having the same problem...it feels really annoying, is it the hardware problem?
Please advise.
