Note 10 Plus not connecting to ipad via Bluetooth when in car
(Topic created: 08-29-2021 02:44 PM)
Note10
Don't get why none of my Samsung phones I've ever had don't connect to my daughter's iPad with Bluetooth in car
Not applicable
Note10
On your Android device go into settings, connections, mobile hotspot and tethering, enable bluetooth tethering. Make sure also that your Android device is discoverable. After you have completed those steps go on to the iPad and go inside of the Bluetooth menu and find the Android device and connect
Note10
Believe I've done this but will try again tomorrow. Thank you for response
Not applicable
Note10
No worries, let me know if it works. One of our ambassadors will gladly help you out 🙂
