Note 10 Plus won't charge through USB or wireless
Hi, I fully charged my phone this morning. Now it will not charge through any cord OR on the charging pad. When it's on the cord, the battery icon in the top right just blinks. When i put it on the wireless pad it shows "Wireless Charging Paused" (nothing about temperature) after 1 second.  I cant find any articles or videos talking about it at all. I have already done the soft reset and deleted the last app i downloaded. Anyone have an actual fix for this problem?
Update, I see the "temp too low" notification now. This blows, it's the first cold day I've been outside
3 REPLIES 3
Re: Note 10 Plus won't charge through USB or wireless
I had an issue like this before and it turned out my wireless charging pad was overheating and had shut off as a safety measure. it might also be a faulty wall socket that isn't supplying full power to the cord. Try another wall plug or cord perhaps?
Nope, I have the notification that my battery temp is too low. No idea what that means but there are a lot of these complaints now!
mine 8s exact same
