Highlighted
Note 10+ S-PEN Not Connecting
Hi folks,
Last night, my Note 10+ suddenly stopped recognizing the s-pen even if it was inserted in the slot. I can still write on the phone and select objects, but it seems that all bluetooth functions such as air actions no longer work.
I've tried multiple solutions such as:
- Removing case
- Soft Reset
- Bluetooth Cache clearing
- S-pen reset function
- Toggle Air actions on/off
None of the solutions listed have worked. I'm wondering if anyone has experienced the same problem with their Note 10+?
Quite frustrating given that this phone is so new and problems like this are already starting to surface.
P. S. The s-pen is samsung official and I haven't gotten it wet or anything. Wondering if this is a manufacturing defect related to the pen's battery capacitor/Bluetooth sensor or maybe something fixable by software
49 REPLIES 49
Highlighted
Re: Note 10+ S-PEN Not Connecting
@Miguel22 Does this issue still appear if your phone is in safe mode?
Highlighted
Hi SamsungQue,
Yes, I've tried starting in Safe Mode and it produces the same problem.
Highlighted
Can you send me a private message using this link here? Provide the following information.
  • Model Number
  • IMEI Number
Highlighted
- Removing case
- Soft Reset
Highlighted
I face same problem with my ben
I have not 10 and spen not recognize but it working While it is working
Highlighted
@usernK3igBKK33 Have you tried resetting the S Pen? Please send a private message with the model code and IMEI number of your phone and a copy of the proof of purchase or lease agreement and I will be happy to see what options are available. http://bit.ly/2XERsky
Highlighted
I am currently experiencing the same issue. Was there a fix for this?
I have tried clearing the cache in addition to restarting the phone. I hope you have a fix.
No matter how much i try it says "Couldn't connect to your S Pen"
Highlighted
Cosmic Ray
If you go to: Settings > Advanced features > S Pen > Air Actions
Does it say Disconnected or Available with battery status beneath?
Screenshot_20191009-173449_Air command.jpgScreenshot_20191009-173503_Air command.jpg
If its disconnected, remove the pen from the phone. Restart the phone and insert the pen to reconnect.
If its Available then it could be an issue with the app. Visit the Galaxy Store, tap the menu in the top right, select "My page" then tap on Updates. I recall the Air Command app was updated not long ago which includes Air action features/functions. You can also search the app store for Air command.
Highlighted
@Disk4mat wrote:
"Does it say Disconnected or Available with battery status beneath?"
If its disconnected, remove the pen from the phone. Restart the phone and insert the pen to reconnect."
 Hi Disk4mat,
Thanks for your reply. It constantly shows "disconnected". Tried your suggested solution a few times and the disconnected problem still persists.
