Highlighted
Note 10+ S-Pen Not Connecting
My S Pen will work on the screen but just out of the blue I got the message "Recconect your SPen" I tried everything from YouTube and from this chat but nothing seems to work. What should I do? The phone is 7 months old and thus is the first issue I had...is it still under the standard warranty?
1 REPLY 1
Highlighted
Re: Note 10+ S-Pen Not Connecting
I had that same issue and turned out I needed a replacement SPen. You can take it to a UBreakIfix store and they will check it for free and verify if just need replacement SPen. If under warranty Samsung will send you a replacement Pen for free if you call and let them know! I got my replacement SPen and no issues!! Good luck!
