Highlighted
Note 10 Temp Too Low
My note 10 is garbage. Wont charge says low temperature. This is the second time in less than 3 months. So now you want me to send it in again?!?! I need a new phone that wont keep breaking. So over samsung phones right now
4 REPLIES 4
Highlighted
Re: Note 10 Temp Too Low
My 10+ just started doing it this week...
Highlighted
Mine started this weekend. Looks like I am going to have to go back to Iphone. 1000.00.
Highlighted
Product Expert
I apologize your having this issue with your device. I understand your hope in Samsung maybe lost. But my recommendation as long as the phone stays on is to back up your information if you hadn't already to an SD card or google accoun. Just in case if you decide to go with a different model device and/or manufacture, at least your information is saved.
Highlighted
Myt note 10 is having the same problem only mine didn't start happeneing until I installed the latest update.
Have you come up with a fix???
This is a well known problem and is allover the internet.
