user1yjQdKVOKQ
Note 10 call drop with bluetooth earbud
I have note 10, and recently I bought soundcore liberty air 2. And whenever I was trying on my phone automatically drops call. Tried on other phones it doesn't happen. Whenever I call with bluetooth earbud it works. But whenever I'm receiving calls it just automatically drops it. I would like this to be fixed.
8 REPLIES 8
Re: Note 10 call drop with bluetooth earbud
Have you tried other Bluetooth headphones?
user1yjQdKVOKQ
Yes I've tried 3 different bluetooth headphone. All of those work on other galaxy's just not on note 10. It works whenever I'm listening to music or other stuff. But only drop receiving calls.
Just to clarify it works when you are making the phone calls is that correct?
user1yjQdKVOKQ
Yes it works whenever I call them. But not when receiving correct
Have you tried wiping the cache partition on your device? Have you tried resetting the network settings? Just a heads up, by resetting the network settings, it will remove all wi-fi and Bluetooth settings you currently have saved.
user1yjQdKVOKQ
I could try that. But I mean I got that phone like 2 weeks ago. Cache and when that was my first bluetooth anything trying on that phone shouldnt really give me problem, no?
user1yjQdKVOKQ
So suggested method did not work :/
I recommend taking the phone to a local uBreakiFix location and have them evaluate the phone. Are you having dropped calls any other time? https://www.samsung.com/us/support/ubreakifix/
