- Mute
- Email to a Friend
03-30-2020 10:50 AM in
Note10I plugged my phone up to charge this past weekend. It will not charge anymore. It stays at 1 % and alarms with low temp will resume charging when temp rises. This apparently has to be a manufacture defect. Especially sense there are thousands of posts about it. What do you expect me to do Samsung?
Solved! Go to Solution.
- Mute
- Email to a Friend
04-01-2020 08:50 AM in
Note10When having a low temperate message on your device that is an indication of your motherbroad having a malfucation . You should go into this link for more inquires and getting a repair : https://www.samsung.com/us/support/
- Mute
- Email to a Friend
03-30-2020 11:10 AM in
Note10Hello 5dZvgT3,
Unfortunately it sounds like an issue with the motherboard or temp sensor. Due to a lot of places shut down at the moment the fastest way in getting it repaired will be contacting 1-800-Samsung and sending it off to them to be fixed. Hope this helps and I'm sorry to hear about your situation.
- Mute
- Email to a Friend
05-05-2020 05:12 AM in
Note10Same thing happened to me .checking the internet did all the restart etc and didn't work then I saw a technician dissemble one and show the wireless connection that can cause the issue. I tapped the phone 3 times below lens toward the middle of the back of the phone and start charging.
- Mute
- Email to a Friend
06-10-2020 06:33 PM in
Note10I took a heat gun to the phone and lightly heated it. Charging resumed without a skip. So wierd. I shouldnt have to do this. But, it worked... im sure a heating pad would work too. But all I'm saying, heat = Charging.
- Mute
- Email to a Friend
08-13-2020 06:29 AM in
Note10This worked foe me. thanks!!!!!
- Mute
- Email to a Friend
03-30-2020 12:15 PM in
Note10Hello,
See if these steps may be helpful.
Get into recovery mode:
1. Hold the power button, the volume up and down buttons.
2. The phone should reboot
2a. Once the phone reboots, hold the volume up button and the power button down.
2b. The phone should go into recovery mode
3. Once its in recovery mode, you can use the volume buttons to move up and down and the power button to select
4. Select "wipe cache"
5. Restart the phone. If that still does not work, repeat steps 1-3, and this time select "factory reset"
6. Restart the phone
If the phone does not even get into recovery mode, it may need further one on one care, and specific attention by a technician to it.
For Samsung Care Authorized locations near you:
- Mute
- Email to a Friend
03-30-2020 01:46 PM in
Note10Hi sorry to hear about the low temp charge. you may PM a @samsungmoderator to help further assist you in resolving your note 10!
- Mute
- Email to a Friend
04-01-2020 07:01 AM in
Note10I'm having the same issue. The first time it happened was 3 weeks after I got the phone. I didn't trip too much bc my phone was on 85% and I was just topping it off before heading out. Later that evening it worked without any issues. In fact it worked fine for a month and then did the same thing again but this time it didn't start back up and I had to place my phone on ultra power save mode. ¹
- Mute
- Email to a Friend
04-01-2020 08:26 AM in
Note10I would be happy to look into this further for you. Can I please have your full model number and IMEI in a private message: http://bit.ly/2JH2rq2
- Mute
- Email to a Friend
07-07-2020 05:29 AM (Last edited 07-07-2020 05:30 AM ) in
Note10@SamsungAdam @I am having the same issue. Would you be able to help get it fixed
