userlp88Koehrc
Note 10 not receiving incoming calls
Over the past 2 weeks or so I noticed that I am not receiving incoming calls. I can make calls and send and receive messages. I only find out about some of the missed calls once I see someone who called or if they send me a text message. They tell me the calls go straight to voice mail. I have checked my settings and everything seems to be okay. If someone does not leave a voice message how can I know who has called me? Has anyone else had this same issue and did you find a solution?
7 REPLIES 7
Re: Note 10 not receiving incoming calls
I would recommend reaching out to you carrier to have them reset your APN or PRL settings. Essentially these are the settings that control your connection to their network towers.
userlsPzGWcCPJ
PRL update and restart worked great. Thanks.
userOCKAZvDJHt
I have been having the exact same issue for almost a month... I have tried everything my carrier has suggested and reset and it hasn't helped... please help
userOCKAZvDJHt
I got some help from a galaxy tech, he had me clear the cache, message In and get directions.. it's helped so far
userC6ScMPNY54
Having the same issue. works after restart. but happens again later.
can you please put more details on what and how the issue is fixed. thanks
userLpvz0kJ1XM
I'm having same problem...... cant send or receive text or calls.  Restart and everything works fine for about a day....
KVDV9598
Setting > connection > mobile network > network operator > select manually > choose your carrier
