Highlighted
Re: Note 10 plus Bluetooth issue
I also would like to be informed of the solution> I have the same problem
Highlighted
Solved!
Go to developers options and enable Turn off A2DP hardware offloadScreenshot_20190909-150650_Settings.jpg
Highlighted
This did not solve the problem for me.
Highlighted
I would like to concur that I have this issue as well, YouTube audio over Bluetooth plays for about a minute and audio drops, video continues to play. About 2 minutes later audio comes back but incredibly choppy, broken and distorted--like the bluetooth round robin frequency hopping is getting out of sync and landing late on each channel.
Highlighted
Note 10 Plus
Model SM-N975U1
Baseband: N975U1UEU1ASH4
The radio in my car is the original radio in a 2014 BMW X6.
Unlocked phone and I'm using T-Mobile
Highlighted
@SamsungCole
I am having the same issue - even got a replacement phone only to have the same issue with the new phone too! The phone will not stay connected to Bluetooth in my car for more than 3-5 minutes at a time. Makes an electrical snapping sound (like a mic is being unplugged?) everytime it disconnects, then reconnects and disconnects again every 5 minutes or so.
Model Code of your Note10: SM-N970U
Baseband Version: N970USQU1ASH4
Model of Radio Head Unit you are connecting to: ?
Bluetooth Version of Head Unit: (Like 3.0, 4.0, etc.) ?
Make/Model of Car if Head unit is in Vehicle: 2011 BMW 528i, factory radio
Cell Carrier for your Note10: Verizon
Highlighted
Bluetooth Issues - Chevrolet Silverado
Having a bluetooth issue while connected to my 2015 Chevrolet Silverado...
If I wake the phone up at all, it switches the source to Bluetooth on my stereo. I don't even have to unlock it...just wake it up and it switches the source over to Bluetooth.
I only want the phone to switch the source to Bluetooth if media is playing or a call comes in, etc... Is this possible, is this an actual design feature, or is this a bug of some kind?
Highlighted
I'm having that same issue. I have to manually turn the bluetooth on each time.
Highlighted
Bixby Profiles was turning mines off when I got close to home and work. I figured it out.
Highlighted
