Note 10 plus how to check Bluetooth battery level
(Topic created: 09-05-2019 10:29 PM)
Broncop3t3
Galaxy Note Phones
How can I check the battery level of my connected akg y100 headphones? On my note 8 I could via smart things. On the note 10 plus it's not an option. Any ideas?
Charkatak
Honored Contributor
Galaxy Note Phones
One of the options is to pull down notification shade, then tap and hold bluetooth icon in the quick panel.  This will take you to BT menu and show you connected device(s) and their battery percentages if supported by connected device.
Charkatak
Honored Contributor
Galaxy Note Phones
Broncop3t3
Galaxy Note Phones
Thanks so much! I was really wanting to be able to check the level!
Charkatak
Honored Contributor
Galaxy Note Phones
No problem.  You can mark as a solution my post so others would just jump to solution
