MrEbanks
Note 10 plus running slow
Notice that my note 10 is running really slow. How can I fix this? I did every step on clearing cache, seeing if a app is running. Nothing seem to work. Wiping the phone isn't a option.
1 REPLY 1
Kcam127
Re: Note 10 plus running slow
Try optimizing your phone in the settings, or try down loading a cleaner app. This seemed to help me, also set your phone up for auto restart and auto optimization. You can also unlock your developer options by clicking it 5 times. Once you go in there you can speed up your animations but setting them to .5X good luck
